PTO stuck
Connie Lawley
04-13-2006 19:29:12
we have a 133 Massey ferguson tractor, i know i have been told there is no 133 well we have one, any way my husband was plowing and hit a stump, and the pto is now stuck, when you let off the clutch the tractor goes dead. did this one time before, and it came loose on the trailer on the way to be fixed
marlowe
04-14-2006 05:32:53
 Re: PTO stuck in reply to Connie Lawley, 04-13-2006 19:29:12
i don't think you are explaning things right first you don't use the PTO for plowing unless you have a tiller and not a plow ????and why do you think it's the PTO that is stuck ?? sounds more like the trans. is stuck in two gears
souNdguy
04-13-2006 20:59:31
Hmm.. i've seen 130 / 135 , 33's and 333's... got any info?
Soundguy
jrsn
04-13-2006 23:13:19
 Re: PTO stuck in reply to souNdguy, 04-13-2006 20:59:31
Link
This site deals with UK and French built Masseys. there are some pics of 133"s , but no info I could find except they had Perkins engines. Ray-s
Connie Lawley
04-14-2006 05:07:58
 Re: PTO stuck in reply to jrsn, 04-13-2006 23:13:19
i found the same site, when i went ot buy parts at three different places they told me there is one such tractor. had to take them pic. but most 135 parst work on it. it is a good tractor. runs great. the first time the pto hung up my son hit a tree with the hay rake. this time my husband hit a stump in a friends garden, the old tractor pull the stump up but now the pto is stuck again.
souNdguy
04-14-2006 13:00:38
 Re: PTO stuck in reply to Connie Lawley, 04-14-2006 05:07:58
Have you tried shifting to Neutral on tranny and disengage pto, then jack up rear end, then put a pipe wrench on the pto shaft and just gently tug in reverse direction.. see what it does?
Is there alot of play in the bearing, or lots of front / back play ont he shaft?
Soundguy
