where to check the steering box lube on a TO35
cvcman
04-13-2006 07:31:36
where is the spot to check fluid level and what is the proper lube to use. I have a TTC manual but for the life of me I dont see this listed ? Thanks again for the help
RegoR
04-14-2006 05:30:42
 Re: where to check the steering box lube on a TO35 in reply to cvcman, 04-13-2006 07:31:36
Hi cvc;
The steering box on my '57 TO-35 w/ power steering is filled thru one of the two upper screws (4 in all) holding the top cover plate. It's full when the oil is at the hole and uses tranny oil (90w GL1).
Roger
melam
04-13-2006 09:59:51
There"s a plug in the top of the steering box under the battery, takes a large flat blade to unscrew, fill it up with same fluid as transmission/rearend (90wt GL-1)
