MF 202 Pwr Steering
Jim Graves
04-12-2006 15:31:19
Hi All, I have a MF 202 with a MF (50??) forklift mast on it. I read here that the 202 is a 35 with a stronger front axle on it. It does not have a PTO or a 3 point on it. It has power assisted steering.
One of the hyd cylinders for the steering has both ball joint / tie rod ends worn out. The cones that go into the steering arm on the king pin and the tab welded on the axle are worn. The chrome rod is 0.625 in diameter and the throw on the rod is about 6". It has 2 each 1/8" compression fittings at the "dead" end of the cylinder.
And the holes in the steering arm on the kingpin and the welded tab on the axle are oversized.
Is there a fix for all this? Will any other model tractors parts fit my 202? Can I cut the tab off the axle and have it welded and re-machined and then weld it back on?
Thanks!!
Jim
