mf-65 and jubilee loader?
lurod
04-12-2006 07:36:50
I would like to find out if a FEL from a ford jubilee will fit an MF-65 propane (1959) tractor.
The loader is self-contained-has its own pump that hooks up to the tractor crank.
Thanks for your replies.
mn.Chuck
04-13-2006 05:28:40
 Re: mf-65 and jubilee loader? in reply to lurod, 04-12-2006 07:36:50
I would find another loader. The rear mounts would
bolt on but the front end would have to be modif.
and the whole issue of the front pump with the
difference in the c/shaft pulley differences!!
A worse issue is that without a major front end
modification you could only steer one way because
the steering arm of a 65 goes across the path of
the hole that the pump shaft would go through. Another loader should not be hard to find,but you
still have to deal with the front pump issue-we
used to use PTO pumps on the 65.
