that darn tractor again''
dave in attica
04-11-2006 16:31:35
have just spent another night in the barn trying to get that damn tractor to start . this started out as it was running when i bought it but now it don,t. rebuilt the motor due to a brocken connecting rod and now i get fuel through both bleeders of the injector pump but it will not punp it through to the injectors. it is a mf31 with a236 perkins diesel engine. any help would keep me from shootimng something. thanks dave
photios
04-11-2006 19:47:49
 Re: that darn tractor again'' in reply to dave in attica, 04-11-2006 16:31:35
Loosen the injector pipe at No 1 injector. turn engine over until you see diesel fluid spurting.
Retighten and it should go.
the preacher
04-11-2006 19:40:52
I worked for a MF tractor dealership doing road service cals. These Perkins engines can be really difficult to prime. My advice would be to keep priming, and check for any leaks. A cracked glass bowl on the bottom of the fuel filter can cause the engine to lose prime, as can a leaking o-ring. Make sure that the entire fuel system has been re-assembled properly, maybe invest in a repair manual, always a good choice. And remember, a tractor is just a piece of iron, not very smart, and incredibly stubborn. Take a deep breath, and you"ll get it. Hope this helps.
