Massey 180 hydraulic problems
Steve Treinish
06-27-2000 19:20:52
Hi, have a 180 that refuses to lift the 3 pt. The loader works great, as does the hyd. pto. The internal valve linkage is OK, but is has a combining valve on the tractor. I took this off and put on a plate a dealer gave me, and now the loader doesnt work. I think this is something stupid, but would love to hear from any similar experiences. Big Dean has been a godsend, but I'
m always up for more input.....Thanks
Matt Abbas
07-03-2000 10:20:30
 Re: massey 180 hydraulic problems in reply to Steve Treinish, 06-27-2000 19:20:52
Steve, We had one and that is a mess in there. There are three pumps in there to supply the three point, aux. hyd. and the multi power. I can't quite remember how they all plumb together so I can't be of much help. We finally figured out we had a broken line inside and once that was replaced it worked better. One thing you might try is the system filter. Our 1100's Hydraulics stop when that filter plugs. Another thing is it only takes a minute speck of dirt or metal to stop Massey hydraulics. It may just be as simple as a stuck valve. Good luck, Matt
Steve
07-04-2000 06:46:26
 Re: Re: massey 180 hydraulic problems in reply to Matt Abbas, 07-03-2000 10:20:30
I took it to the local shop. I give! What is throwing me, is I have a 165 also, and it has one of the pick one-remote,remote, or 3pt kinda valves. When I take it off, my 3 pt works OK. I did this on the 180 and lost my loader and the 3 pt still didnt work....My guy is gonna put the gauges on it, and probably pop the tranny top and go from there. The filter was a guess for me too. Thanks for the help....
Matt
06-30-2000 11:49:14
yOUR OIL IS NOT PROPERLY ROUTED TO THE LOADER. iN OTHER WORDS YOU ELIMINATED THE OIL SUPPLY TO THE LOADER.. RECHECK YOUR oil supply to the loader
Steve
07-03-2000 08:46:45
 Re: Re: massey 180 hydraulic problems in reply to Matt, 06-30-2000 11:49:14
I figured I did that. My question is, is there a routing diagram that covers the combining valve? I cant understand if I put the cap on in the valves place, why did I lose my loader?
