Removing the rear wheel and tire is not hard if you are set up to handle heavy weight. Be careful as you can get hurt if you don't keep things under control. Let me ask a could of questions? Why are you taking it off? are you going to repair the wheel or rim or do something to the tire> Of are you taking it off because you need to get at the brakes or rear axle? Do you have a 8 ton or heavier hydraulic bottle jack? Do you have some 2' long 6" by 6" or 8" by 8" to support the jack and the tractor while the wheel is off> Do you have a flat concrete area where you can work? Not necessary, but awfully handy and safer. Do you have another gractor with a loader that can lift and swing the wheel and tire clear when you get the bolts out? Do you have an air impact wrench with an impact socket of the correct size? Or can you get a 3/4' drive cocket set with a flex or sliding T handle that you can put a length of pipe on if necessary. Experiment with getting some bolts loose one by one and then tightening the snug before you jack the tractor up and start to take them all out at once. It the bolts are really tight, try dripping penetrating oil nywhere you can get at then and tapping then with a hammer at intervals. If you don't have something like a tractor loader to suspend the tire and wheel when you take it off, then have plans to have enough help so that you can roll the tire away from the tractor without it getting away from you. Does the tire have fulid ballast in the tires to increase weight? You can have the fluid pumped out and then put in again if you are going to ahve a hard or dangerous time handling wheels with fluid in. Good luck, tell us how it turns out or email is for further advice. It was not clear from your question where you anticipated having problems.
