Massey 135
James K. Geoghe
04-07-2006 10:54:12
Hello:
I am very new to the world of tractors. I am buying a house on a large lot that the currrent owner uses a Massey 135 to keep bush hogged. I have the oppertunity to buy this tractor for $2500.00, it is a gass powered 3 cyl. Are there any kniwn issues with this tractor that I should be on the look-out for?
Thanks
James
MF Poor
04-08-2006 03:18:48
 Re: Massey 135 in reply to James K. Geoghegan, 04-07-2006 10:54:12
Jump on it! That's about $.50 on the dollar what a running 135 would sell for here. Best small tractor ever built.
Look for oil dripping from weep holes under transmission and bell housing. Might show signs of leaking oil pan gaskets. Stay far away from tractor with multi-power unless you really know it's OK.
Should you buy it, get MASSEY FERGUSON owners manual, service manual, and parts manual. IT manual is good to set your sandwich on while reading REAL manuals. Also contact "Big Dean" (on here) to get his CD on 100 series Massey's.He can walk anyone through all the steps to repair anything on the 135.
AGCO/Massey still carries all the parts. Tons of aftermarket parts too. Best part is, they aren't "parts hungry" like some old tractors. Sone reliable.
I'd act fast. 135's don't last long at that low of a price. ESPECIALLY at this time of the year.
globeflyer
04-19-2006 21:13:30
 Re: Massey 135 transmission stuck in 3rd gear-Help in reply to MF Poor, 04-08-2006 03:18:48
I've got a massey ferguson 135 continental gas, 3 speed transmission with high/low range. It is stuck in first gear. Any quick fixes to get it out and shifting normally?
Thanks,
Randy
jerrycpp
04-07-2006 20:38:24
I have a Massey 135 Perkins gas and wouldn't trade it for anything. I paid $3000 for it 5 years ago, and it needed tires and engine work. It has a front blade and that's the reason I needed it. Parts are easy to get, it is totally reliable, and a pleasure to use. ALWAYS let the starter spin down completely before trying a restart - a broken starter housing is pricey, as is the drive. Get a #MF-27 Intertec manual for it, and an owner's manual on line or from the dealer. Adjust the clutch and brakes, change it to a spin-on filter if it hasn't been changed already*, be sure the hydraulic oil is clean, and enjoy it. *The original can-type oil filter had a special spring and washer that is not available and is ususally lost the first time the oil is changed.
ng
04-07-2006 19:15:06
I have a 2135 which is the Industrial Equivalent. Great tractor. Mine has a continental engine. I would never sell it! Starts great, runs great and is a nice, small handy tractor. $2,500 sounds good
Badly Bent
04-07-2006 12:52:36
If it's in good shape and well cared for it is probably well worth that price. Check for leaks, bad clutch, brakes, sloppy steering, etc.
Tim
supergrumpy
04-07-2006 12:32:24
I've got one and its terrific, not too hard to work on and parts are available
look at the current owner, if he takes care of his other stuff and the tractor looks like its been cared for, maybe even kept under a shed, jump on this deal or tell me where it is located and I might
KJAKX
04-07-2006 14:44:56
 Re: Massey 135 in reply to supergrumpy, 04-07-2006 12:32:24
Parts are readly avalable for this tractor, and the aftermarket supports a lot of parts for them too. That is two good sighns of a good tractor to buy if the tractor itself is in good shape. The 3 cyl Perkins engine is well known for good reliability. But i promise you one thing, at some point in time, it (or any other tractor you can buy) WILL break down. So keep that in mind when shopping. Most parts for the 135 are fairly cheap compaird to 'bota parts and the green machines.
