MF 85 Pwr Str Leak
OK Don
04-06-2006 18:59:51
Hyd fluid is being forced out from the cover over the power steering worm gear. The vertical column is filling and the I can see fluid coming up around the spline of the verticle shaft. I have replaced the seals on the verticle shaft and also on the worm gear shaft. I suspected it was leaking by the hyd cyclinders but the verticle column fills up and leaks through the worm gear box even when the steering is in neutral and no pressure is being ported to the cylinders. The control valve appears good. Thanks
