MF 65 oil leak, dip stick
Tom in Wis.
04-06-2006 10:57:20
My 1959 MF65 has a gas continental engine. When I work it hard at higher RPM's it pushes oil out around the dip stick quite badly. This is the original dip stick. Is there suppose to be an O ring or seal or do I have a breather some where clogged? Thanks in advance.
Ed Lottterman
04-06-2006 22:53:13
 Re: MF 65 oil leak, dip stick in reply to Tom in Wis., 04-06-2006 10:57:20
You have some blow by and you may have some sludge clogging your breather tube. I don't remember on those, can you remove the breather without taking off the whole rocker cover? If so, take it off and blow compressed air through it or even a water hose if you have good pressure. Let it soak in solvent or gasoline and run a wire through it and pull a cloth patch back. That breather should handle a lot of gases and unless you really have a lot of clearance between piston and sleeve, you should not be blowing stuff past the dipstick.
I guess one question is, do you feel a lot of hot gases leaving breather tube when it is standing still running at 2000 rpm or so? And does your oil get dark with a lot of soot or combustion products in it soon after you change oil?
james vaughn
04-06-2006 19:25:19
older engines some times develop blow by or compresion going by the rings. or the crank case vent is not working right. i suspect when under a load there is gasses passing the rings.or blow by as it's called. james
james vaughn
04-06-2006 19:25:13
