MF 135 hydraulic pump question
Scott
06-27-2000 14:07:11
I have an AC 160 that has an "airequipment" hydraulic pump. I am having trouble getting a seal kit to rebuild this pump that has all of the softwear, and the correct stuff in it. I've been told that my tractor has the same engine as the MF 135 (perkins 3 cyl 152 cid diesel). Is there a chance that I could get pump parts, or a rebuilt pump for the MF tractor and bolt it on mine? Thanks for your help!
John Miller, III
06-27-2000 15:10:07
 Re: MF 135 hydraulic pump question in reply to Scott, 06-27-2000 14:07:11
The only common thing is a Perkins 152 diesel engine. Your AC has completely different hydraulics, transmission, rearend, 3-pt lift, etc. etc.
Check with an AGCO Allis dealer, they should fix you right up!
scott
06-27-2000 18:58:17
 Re: Re: MF 135 hydraulic pump question in reply to John Miller, III, 06-27-2000 15:10:07
Thanks for the reply. I' have driven the nearly 100 miles to see the AGCO dealer, and bought parts for this pump. However, the only seal kit available from the dealer doesn't even contain the shaft oil seal. He did (I believe by mistake) sell me a seal for the Plessey brand pump that they use on the same model tractor, but my pump is an Airequipment brand, for which he sold me the only available seal kit, which (again) doesn't contain the shaft seal. He sent me a copy of the parts list and diagram for the pump, and after spending some time with it, I don't see any other softwear available for this brand of pump on this tractor. So, I'm looking for other optiobns. I'm interested in hearing from anyone who has ideas. Thanks!
