MF135 water leaking from wheels
John Caldwell
04-04-2006 13:40:13
I just noticed this past weekend that water seems to be seeping from my water filled tires through the rims (MF135 1965 cont gas). I have had the water in the tires for about two years which really has helped with weight and traction. In that I live in an area that doesn't freeze, I didn't need to add the calcium.... just water. Don't know why the water would be seeping through the rims (where the wheel wings are welded to the inside surface on the rim). When I put on the tires two years ago, the old tires had inner tubes, the new tires are tubeless. I have no idea if the previous owner had ever used calcium, but I doubt two years of plain water would cause a rusting problem through the rim. Is there any way to stop the seeping or do I just put up with it until I need new tires, or simply put inner tubes in the tires? Is there some type of stop leak that might work?
TomTX
04-04-2006 20:41:49
 Re: MF135 water leaking from wheels in reply to John Caldwell, 04-04-2006 13:40:13
I would pull the tires off, clean and inspect.If rims are OK condition prime, and paint the inside of the rims. Then use tubes even though the tires may be tubeless.
Tom
Aaron Ford
04-04-2006 17:47:04
Tubeless? Didn"t know they made em. Sounds like you have a hole in your tube, or a hole where the tube needs to be. The calcium is highly corrosive and your wheels will be totally destroyed if left in contact with the calcium long. Water is less so, but will still corrode if left in contact with the steel. I am relatively sure that no steel wheel was designed to be in direct contact with water. It sounds as if you have some wheel repair work ahead as well.
