Gray Smoke, Black Smoke??
Robert Marzi
06-28-1998 17:55:21
I had a chance this weekend to run the TO-35 I am rebuilding for quite sometime and I noticed it is pushing a little gray/white smoke out the exhaust. Could this be from a to rich gas setting or do you thing it is oil being pushed through the cylinders?? I was once told that if it is black smoke it was oil and if it was gray it was coming from the fuel mixture. Any truth to this??
Regards,
Bob
Gerald
06-28-1998 19:55:45
 Re: Gray Smoke, Black Smoke?? in reply to Robert Marzi, 06-28-1998 17:55:21
: I had a chance this weekend to run the TO-35 I am rebuilding for quite sometime and I noticed it is pushing a little gray/white smoke out the exhaust. Could this be from a to rich gas setting or do you thing it is oil being pushed through the cylinders?? I was once told that if it is black smoke it was oil and if it was gray it was coming from the fuel mixture. Any truth to this??
: Regards,
: Bob
Black smoke is burning overly rich gasoline.
Oil burns blue.
Gray/white could be unburned fuel (some cylinders not firing).
Gray/white could be water vapor (leaking head gasket).
Gray could be some black from running too rich in some cylinders mixed with white from not firing in other cylinders. Catch a sample in the palm of your hand and smell it. If its got fuel it will smell like gasoline. If water, it won't smell. If oil, it will have a tinge of oil odor.
DaBrow
06-28-1998 18:04:44
: Regards,
: Bob
