MF 20c steering problem
mikestractor
04-03-2006 17:11:08
Recently I had to put on a new belt which required pulling the front hydraulic pump. Since then my steering at times does not work properly. You can turn the wheel while driving and the wheels do not respond immediately. It will turn but it makes a really wide turn. Any ideas would be appreciated.
Big Dean
04-03-2006 20:58:32
 Re: MF 20c steering problem in reply to mikestractor, 04-03-2006 17:11:08
You may have air in the system try bleeding it. Bleeding the air out of the power steering system. You always fill the reservoir with the engine running. After you have it full, turn the wheels from stop to stop several times to disperse the air from the system. You may have to fill the reservoir a couple of times if there is a lot of air in the system.This is done with the plug out
mikestractor
04-04-2006 03:26:49
 Re: MF 20c steering problem-Big Dean in reply to Big Dean, 04-03-2006 20:58:32
Can I use Permatran hydraulic fluid or is there a MF power steering fluid I should use. To bleed it out, just removed the bolt on the right side of the power steering pump?
Big Dean
04-04-2006 05:33:49
 Re: MF 20c steering problem-Big Dean in reply to mikestractor, 04-04-2006 03:26:49
Yes Permatran 3 is what is used in the power steering on them.
