TO-35 hood latch
Phil Leithold
04-03-2006 09:36:02
I have a 1955 TO-35, It has button type latches for the center part of the hood where you put the gas in.Where can I find one? I haven't had any luck so far.
mn.Chuck
04-04-2006 16:39:28
 Re: TO-35 hood latch in reply to Phil Leithold, 04-03-2006 09:36:02
Hi Phil, Heres the deal. The Depot has the front
button and lever(bracket)and the 3 hdwe pieces-but
not the spring-improvise?I don't know. And these
pieces because of their status are very expensive.
They total 39.71 and they chg extra to customer
direct. Ship 6.50 ? The process could speed up if
you had a local dealer they could ship to and you
could p/u. I will list the p/n's. Button-180680M1
Lever-180644M1,spring 180647M1(none) rivet180518M1
screw-353954X1,Pin 764055M1. Hoping someone out
there has the spring or some used parts. If you
need this route I would need $46.21 and no spring.
Chuck Bergstrom,PO Box 295, Buffalo, Mn.55313
763-682-2699
All Dealers have access and phone No.to the Depot
Phil Leithold
04-04-2006 08:20:15
I need the front button and spring and the piece that the spring fastens to. The piece that fits on the part of the hood that opens looks fine.
mn.Chuck
04-03-2006 15:32:23
A total of 9 items including springs and rivets
etc make up all this. The front button is diff.
than the rear-also the levers. How much stuff do
you need? The buttons are riveted to levers and
ea have a seperate special spring. The "Depot" in
Chilton, Wi. has one of the buttons and a couple
of the other parts but not all. If you need all
parts they can't get you going but E mail me for
part numbers and a local dealer can order from this parts depot if they are accommodating. Chuck
