Pony ???????
hunter
06-24-2000 17:46:53
help me out yall, found a pony with the motor torn down. what is it worth? all parts there. also what sort of horsepower did they have and what about lift system? thanks
Jason
06-25-2000 07:47:31
 Re: pony ??????? in reply to hunter, 06-24-2000 17:46:53
Not sure about the worth of that pony. But the motor is a contential 62 cubic inch engine that produces about 12 horse power. The Nebraska tracter test says 11.56 hp to be exact. All ponys made before 1950 had a manual lift, but from 1950 up has hydraulic lift.
Mike from Ontario
06-25-2000 06:14:32
Hunter
Depending on the tin work, probably around $500 if the motor is torn down and you can't hear her run and drive. I think the horsepower rating is somwhere around 15 to 18 hp, and some came with hydraulic lift as well as manual lift on the earlier ones. Hope this helps
Mike Leggett
