MF65 Brakes
kazenza
03-26-2006 20:29:19
I'm replacing the brakes on my 1960 MF65, and when I pulled the axle housings the brakes on both sides were soaked with oil. I'm presuming this is not what I'm supposed to find, since there are seals at both the differential carrier and the Planetary housing. So I should probably replace seals as well as brake disks. Any confirmation on this. Also, do I have to have the seal on the differential carrier pressed or can I tap it in with a block or disk?
Randy
Kazenza
03-27-2006 18:48:41
 Re: MF65 Brakes in reply to kazenza, 03-26-2006 20:29:19
Well, I'm definitely not worried about dust since my brakes have converted themselves to a "wet oil" braking system. Hard to beliee they
Yeah, they're heavy, but not nearly as hard to move around as the wheel weights that came on this thing. They're still sitting on the ground where they fell. Randy
Aaron Ford
03-27-2006 05:57:29
You are correct. The seals need replaced if the brakes are wet. Look inside the axle housing and see if the oil is coming from the planetaries. Mine was not. I simply replaced the differential seals. The diff carrier bearings can be renewed at this time, if needed. I still have 4 extra planetary seals if ya need 'em. On the diff seals, lay the plate down on two blocks of wood. Place a chisel through the axle hole and into the seal and smack the boogers out of it. It should pop right out. It will likely come out in pieces, especially if it was installed backwards like my right side. Also, be sure the weephole coming from the center of the seal and draining outside the axle housing is clear. I tapped my seals in with a 3 lb hammer, being sure that it engaged evenly. It will bottom out, so there is no fear of overdriving it. You can buy the seals off eBay for much less than your local jobber, if he even has 'em. The is a seller on eBay called Porter8N that will wheel and deal over the phone and is extremely reasonable on the shipping. I think both of my seals ran me eight bucks including shipping from him. My discs were $13 dollars from Stephens in Ripley, WV 304-372-5200 (ask for Aaron) and he shipped UPS. BTW the numbers on your carrier bearings are 3942 Left and 29590 right, if ya happen to need em. Bearings run between 20-30 a piece (I have an extra 3942 if ya need it), but they will tell you anything. I was quoted 53 bucks for the 29590, but the price dropped to 30 even when I protested. Contact me here or at [email protected] and we can discuss price for my suplus items. I also have spare bearings for the front wheels, but I cannot recall exactly what I have. I will dig em out if you are interested. In all, it is a fun job except for the whole lifting thing. I unbolted my planetaries and that lightened the axle enough for two people to easily? handle. It also gave me a good opportunity to clean any sludge from the differential area. Check out the pics in my Sludge removal post. Aaron
kazenza
03-27-2006 06:46:28
 Re: MF65 Brakes in reply to Aaron Ford, 03-27-2006 05:57:29
Aaron, thanks for the detailed post. I'll probably replace all the seals on both sides since I'll need to pull the axle housing off the planetary for better access to clean all the sludge out of the housings. My bearings look fine, no pitting or roughness. My biggest problem at the moment is one of the brake discs seems stuck on the Axle, making it impossible to remove the actuator. I may take you up on the seals, but I'm going to check my local Massey Dealer first, who seems to overcharge on a lot of stuff (like $8 for a gasket I got for 1.65 from Tom Dold on this list, but is okay on some things. I've got a lot of sludge in my diff as well in my transmission, which I'm looking forward to flushing out. Randy
Aaron Ford
03-27-2006 11:28:52
 Re: MF65 Brakes in reply to kazenza, 03-27-2006 06:46:28
To remove the stuck discs, (all mine were stuck) take a real dull chisel and approach the disc from the actator rod hole. You can actually get a little rowdy here as the fibrous disc gives before the steel of the actuator. The disc will tip, then move to the opposite side. Presoaking with penetrant helps. After a few laps around, it will come loose. The outer disc is harder. However if you are going to disassemble the planetaries, remove them , and support the outboard end of the axle on end on a couple of spaced 2x4's. Then soak and tap around on the disc near the axle to loosen it. Now use a brass hammer or a piece of oak to protect the axle and strike the end of the axle driving it out of the disc. I used a 3 lb steel hammer, but was careful to hit it squarely. The first side took me an afternoon, the second side took 25 minutes. I marked my planetaries upon disassembly to be sure they go back the same way, but I don't see any reason to other than the book said to do it. I also used dry graphite lube on the axles at the slide points. I did'nt want to put anything wet here so the graphite was the only remaining choice. I should also add that the discs you took out are asbestos. The ones you reinstall are likely mad from the same. Take necessary precautions if you have any dust. I didn't cause it was soaked in 90 weight oil... Putting the actuator balls on the wire wheel of the grinder cleaned them pretty good. I lubed both the balls and all nonfriction surfaces of the actuator with the dry graphite as well. Good Luck Aaron
PS Axles are heavy ain't they?
