MF 135 Backfiring Problem
DA Hesse
03-24-2006 14:17:06
I have a MF 135 with a 3 cylinder perkins engine. It idols fine at 500rpms but as I increase the throttle it begins to sputter and backfire around 1500+ rpms. I have checked the timing, points, replaced the coil, plugs and wires. I have cleaned the carburator. It seems that as I adjust the choke it runs a little smoother. My guess is that its the air/gas mixture, but with the Zenith Carb there is only one valve adjustment. Any help on my next course of action would be greatly appreciated!!
smilie
03-25-2006 06:17:27
 Re: MF 135 Backfiring Problem in reply to DA Hesse, 03-24-2006 14:17:06
i have the same problem with my model 20 with the AG3 152 perkins. you need to replace the solenoid at the bottom of the carb. had to replace about two years ago and it"s out again. just ordered one from the massey dealer for 69.00. the older masseys had an adjustable one, but the new ones are a sealed unit.
