Generator replacement?
IMKCMAC
03-22-2006 16:18:00
I have a MF 135 with the Continental 4cyl engine and the wrong generator to run the tractormeter.I haven't had any luck finding the correct gen with the gear set-up on the rear to drive the tach cable.I want to be able to use the Tractormeter so what other options do i have to get this done?Did they ever use an alternator to do the same thing?Thanks.
Massey 50
03-24-2006 20:39:58
 Re: Generator replacement? in reply to IMKCMAC, 03-22-2006 16:18:00
I just recently ran into the same situation with my Massey 50. I located a parts business in West Siloam Springs, Oklahoma by the name of Mac Tractor Parts(1-800-882-4742). I was able to get the tach drive kit from them. They may be able to help you.
Aaron Ford
03-22-2006 19:16:34
There is a guy selling a setup on eBay to replace the generator with an alternator. Different brackets, wiring, and a one wire alternator. He also sells a kit with a tach drive. It goes for about 169USD. The alternator is a much better option for those that use their tractors regularly and are not concerned with total originality. Paint it Flint Gray and most folks will never see it.
IMKCMAC
03-22-2006 19:46:28
 Re: Generator replacement? in reply to Aaron Ford, 03-22-2006 19:16:34
Do you have anymore info on than that?Thanks.
Aaron Ford
03-23-2006 18:53:36
 Re: Generator replacement? in reply to IMKCMAC, 03-22-2006 19:46:28
This guy sells conversion kits through eBay. He list that for 30 extra dollars he will include a tach drive. You will have to talk to them about fitment on a 135. I cannot forsee any problems, though. I believe they use the same setup. Aaron
