285 good and bad points?
fudpucker
03-21-2006 12:51:56
I am looking for a second tractor and these seem to be pretty affordable in my part of the country. It will be used for hay baling, raking and such. what are the good and bad points of these tractors?
jogl
03-22-2006 03:11:10
 Re: 285 good and bad points? in reply to fudpucker, 03-21-2006 12:51:56
Our 285 has been really good to us.
Don-Wi
03-21-2006 20:05:26
We've got one, had it since new and now we've got over 6100 hours on it. The head leaks oil down the side, like BigMarv said will happen, but it still runs good but is finally needing a rebuild. It used ot be our big tractor for almost 20 years, now we run an Oliver 1855 pushing 105 HP.
Our 285 still does all of our haying, (cutting, raking, and baleing w/ a #12 baler)
Depending on the size haybine you use and what you do with it, you may need to work it hard once in a while if it starts to slobber a little out the muffler.
We generally run a 9' 290 NI mow/ditioner, but we have also run a 14' Hesston hydra-swing with it.
Donovan from Wisconsin
BigMarv1085
03-21-2006 15:08:53
I have a 1085 which is the same tractor except it is the row crop version. The head bolts will stretch and the head will gasket leak. the hydraulics are on the weak side. I think it is a good mid size tractor. I maintained 400 acres with this being the main tractor. Kind of hard finding a used harrow for it because there is more used equipment for 60 -70 and 90-100 horsepower tractors.
