M.F. 231 does not move
Craig Goerig
03-20-2006 07:16:17
I was pulling a truck from a ditch when I heard a knock around the diff. area and the wheels quite turning. I know the cluch is good because I can see the gears turning in the trans.Does the tractor have a shear pin somewhere? what is involved in the repair? Any info will be helpfull. Thank you
TRC
03-20-2006 08:32:17
 Re: M.F. 231 does not move in reply to Craig Goerig, 03-20-2006 07:16:17
Craig:
My 135 has a coupling that is designed to break if the torque is too great for the drivetrain. I'm not certain about the 231, but I would bet that you have something very similar. Can't remember exactly how to repair it off the top of my head. Check with Big Dean; he'll get you pointed in the right direction. You might want to buy one of his CD's as well. They have a lot of extra pointers. Tim
souNdguy
03-20-2006 07:48:45
I'd look to see if you have a coupling tube between tranny output and pinion.. next would be to check for shorn rivits inthe ring gear..
Soundguy
