MF 35 Question
Tim Tenn.
03-20-2006 05:42:13
I'm looking at what I Think is a MF 35 or possibley a Ferguson 35. There isn't any tags on it or decals. It has a 3cyl. Diesel, high/low 4 speed. It doesn't have live PTO. It has a dual control valve with a loader working off one side and the lift working off the other. The lift stops when you clutch it. I thought 35's had live hydraulics? It has position control. Is this a proper set up of the hydraulics? If I wanted to use it for duel remotes, would it work the lift off the quandrent control? The tractor looks ruff but sounds good, the hydraulics lift good,but leak down slowly while running.(lift cyl. rings?) Steering has a lot off play ( not power steering ) Can power steering be added? He's asking $1800.00 with a trip loader and a 5ft. bushhog. Is it worth it? Thanks for any help you can offer.
mn.Chuck
03-21-2006 16:10:05
 Re: MF 35 Question in reply to Tim Tenn., 03-20-2006 05:42:13
try posting the s/n from the tractor. Not many of
us have heard of a 4 sp. Should be hi-lo range
lever with 3 speeds on the main lever. Not very
feasible to add a power steering. Chuck
