MF255
jerry (AL)
03-17-2006 15:54:28
I'm beginning to have a real annoying problem with the tractor. Takes forever and a world of jiggling to get the starter to engage like the neutral switch is going kaput. Can't seem to get the HI/LO in the correct position for it to turn over. How difficult is it to repair this? I realize you can probably bypass this switch some how but do not want to even consider due to the obvious danger it presents.
lonestarjeff
03-19-2006 14:35:18
 Re: MF255 in reply to jerry (AL), 03-17-2006 15:54:28
Would the setup be the same in my 165? I sometimes have to reach in & hold the 2 neutral switch wires between thumb & forefinger, then push the wires down a little while hitting the starter.
I've never had to mess w/ the hi/lo shifter, other than bump it into neutral.
Jeff
MF#1
03-19-2006 16:10:40
 Re: MF255 in reply to lonestarjeff, 03-19-2006 14:35:18
Yes, should be fairly close. Maybe you have a bad wire or connection? Clean up the wires and check for continuity with an ohm meter. MF has the switch.
MF#1
03-17-2006 18:32:50
Jerry, "Sometimes" it"s the starter solenoid going bad if it "clicks" until it cranks. "Usually" when the neutral switch is bad it stays bad, but not always. The neutral switch is fairly easy to replace, just in front of the panel nearest the L-N-H shifter, two wires to unplug and swap the neutral switch out. I would straight wire it once to be sure it"s not the solenoid. I have "fixed" the solenoid by reversing the brass contact where the bad connection is(where the + cable goes to the solenoid).
Jerry (AL)
03-18-2006 06:45:28
 Re: MF255 in reply to MF#1, 03-17-2006 18:32:50
Pretty sure it's the neutral switch.
I get no clicking at all. Just won't turn over without jiggling the hi/lo shift lever. FInally you get the lever right in a certain position and it will crank. Have to get it in neutral position and then wiggle it over to one side and jiggle it up wand down in the neutral position. Every time I crank it, it seems to get worse.
MF#1
03-18-2006 10:07:13
 Re: MF255 in reply to Jerry (AL), 03-18-2006 06:45:28
Yep, that smells like a neutral switch, shouldn"t be too hard to swap out. We changed one out of 3 since 1975 so they have worked well, may go bad tomorrow though.
