MF 65 Power Stering problem
Jrry
03-16-2006 09:25:19
third party image
I have two MF 65 tractors with power steering but only one is working. One tractor has a different configuration than the other. The one with the fluid resivor works and the one without does not. Both have the same congiguration behind the grill. I will try and post pictures of both. Need to know what I need to get the second one working, thanks. Jerry
Bob N.Y.
03-16-2006 17:19:17
 Re: MF 65 Power Stering problem in reply to Jrry, 03-16-2006 09:25:19
Have you tried making adjustments to the linkage behind the grill to compensate for wear?
mtaylor449
03-16-2006 15:15:19
anyone know where i can get the powersteering lines shown in the first picture there are steel and rubber with specail ends . ive been to the only two dealers around me they say there are no longer avilable. they tired to repair the one but it still leaks. I have the part numbers here somewhere.
thanks mtaylor449
Ed Lotterman
03-18-2006 13:01:36
 Re: MF 65 Power Stering problem in reply to mtaylor449, 03-16-2006 15:15:19
Have you tried taking one of your lines to a specialty hydraulic place like Pirtek? I'm not sure where you live. There is one of these near where I live it St. Paul MN. If you bring them an existing line they can make up something nearly identical and they have all sorts of ends - metric, SAE, etc. I don't know if they are nation-wide.
mtaylor449
03-20-2006 15:04:14
 Re: MF 65 Power Stering problem in reply to Ed Lotterman, 03-18-2006 13:01:36
Yes i have But i think the guy was upset because i showed up just before he was to leave for the day. Nobody want to work any more.
thanks
mtaylor
mtaylor449
03-16-2006 15:03:49
yes it does have a resevoir it's the tin can attached to the pump housing where your hydraulic lines are. it appears you have a brass valve there. mine has a plug at the 10 o clock position . it only holds about two quarts of oil including the lines and cylinder. I believe there is also a filter in there too. I have the parts book but no servive manual on it.
hope this helps
m taylor
Jrry
03-16-2006 16:09:32
 Re: MF 65 Power Stering problem in reply to mtaylor449, 03-16-2006 15:03:49
that helps a lot. I see abouit adding some fluid there. I hope that all that is wrong with the power steering. thanks
Jrry
03-16-2006 09:40:05
third party image
picture of non working power steering
Eric in IL
03-16-2006 15:30:15
 Re: MF 65 Power Stering problem in reply to Jrry, 03-16-2006 09:40:05
The picture looks like the bottom line on the pump might be leaking - (badly). Try opening the brass valve and adding some power steering oil.
Jrry
03-16-2006 16:07:29
 Re: MF 65 Power Stering problem in reply to Eric in IL, 03-16-2006 15:30:15
thanks, I'll try that. The guy I purchased it from told me it did not have power steering so I did not question it at the time but discovered later that it does have the power steering set up.
Jrry
03-16-2006 09:32:12
third party image
trying again to post picture
Jrry
03-16-2006 09:38:30
 Re: MF 65 Power Stering problem in reply to Jrry, 03-16-2006 09:32:12
third party image
picture of resivoir of working poser steering
