Fuel pump for Perkins engine in Dexta
Oregonfarmer
03-14-2006 08:41:33
I need the diesel fuel lift pump for my Fordson Super Dexta with Perkins engine (Ford-Perkins).
This is a 3cyl, but not a AD. Would any MF diesel pumps fit?
DavidP, South Wales
03-14-2006 14:20:59
 Re: Fuel pump for Perkins engine in Dexta in reply to Oregonfarmer, 03-14-2006 08:41:33
Hi,
Seems like you are talking about both fuel pumps. If you are on the main pump then the answer is definately NO. If it's the lift pump then the answer is 'yes' The block fitting on 3 cyl engines is the same.....those with two studs.
Later 135's had 4 studs.
David P
woodache
03-14-2006 11:21:40
 NO! Re: Fuel pump for Perkins engine in Dexta in reply to Oregonfarmer, 03-14-2006 08:41:33
Simple to say NO, Different system totaly, Dexta has Simms IJ pump MF P3 uses CAV :((
