MF 1135 oil cooling lines
Jeff Tucker
03-11-2006 04:03:59
I recently bought a 1135 and after checking the tractor over I found that the two lines coming from the oil filter base are looped together instead of being hooked to the radiator. How will this affect the tractor and is it ok or did someone do it because the radiator may be bad ?
barnrat
03-11-2006 10:26:04
 Re: MF 1135 oil cooling lines in reply to Jeff Tucker, 03-11-2006 04:03:59
Sounds like the oil cooler got a leak and some one by passed it, if it's the engine oil your talking about. If that's the case then you can use the tractor but I wouldn't work it real hard untill you got that oil cooler fixed.
jim22
03-11-2006 07:14:58
Which oil filter, hyd or engine?
Jeff Tucker
03-11-2006 18:06:14
 Re: MF 1135 oil cooling lines in reply to jim22, 03-11-2006 07:14:58
It's the engine oil filter and they used to hook in to the bottom of the radator.
