Engine won't start 3545 Massey
Donnell
03-10-2006 20:56:20
Sowed fields early Oct. Put tractor in barn. Tractor working fine. Went back 3 weeks later and engine would not start. Would only turn over slowly. Checked batterys, leads, and starter. All ok. Tried to turn bell housing with screw driver. Moves about 2" and stops. Something cause resistance. What is wrong?
AllanC
03-12-2006 13:19:41
 Re: Engine won't start 3545 Massey in reply to Donnell, 03-10-2006 20:56:20
You don't say gas or diesel, but coolant in a cylinder is always a possibility. remove spark plugs & see if it turns (glow plugs on a diesel)
Donnell
03-12-2006 13:39:51
 Re: Engine won't start 3545 Massey in reply to AllanC, 03-12-2006 13:19:41
Diesel Perkins. Pulled tractor out of barn. Tried to pull in high gear to start but would not turn over engine. I can still turn engine over slowly with starter. Could the hyd. clutch not be releasing? Clutch peddle has no resistence when pressed down.
