Calling Big Dean Austin - look at my MF 255 trans
fixitforfree
03-10-2006 05:15:47
I was told you were the MF man. Could you please post some info concerning my MF 255 trans problem below this thread? Thanks.
Big Dean
03-10-2006 07:16:02
 Re: Calling Big Dean Austin - look at my MF 255 tr in reply to fixitforfree, 03-10-2006 05:15:47
The Main clutch disc is slipping. Either it is just worn out or the clutch has no pedal free travel if not it needs to be adjusted.
fixitforfree
03-16-2006 05:29:44
 Re: Calling Big Dean Austin - look at my MF 255 tr in reply to Big Dean, 03-10-2006 07:16:02
I sure hope you are correct. I just think it's strange that when in lo-lo, it barely pulls itself then with the slightest touch of the brake, it stops the tractor completely - I can't smell ANY foul odor like the disc is slipping at all. The tractor doesn't jump or make any bad noises at all. You still think it's most likely that the clutch is slipping? How, exactly do I adjust this 255 clutch? It is disengaging fine because you can use the clutch to switch gears without any gear scratch even with the engine at high rpms. Thanks for you help Big Dean.
