distributor for massey mf 230
Tractor101jrh
03-09-2006 12:20:17
Need a distributor or the drive gear on bottom of distribtor for massey 230 with z145 gas engine
anyone know where to find one
Ed Lotterman
03-09-2006 21:20:21
 Re: distributor for massey mf 230 in reply to Tractor101jrh, 03-09-2006 12:20:17
Is the existing gear worn or don't you have it at all? I think this is the basic Delco distributor and it got used across a lot of different applications. I had a 1963 gas MF 180 that had a Delco 4-cylinder distributor and then years later I had a Larson boat with an OMC sterndrive that used a 4-cylinder GMC gas engine. Same basic distributor although I cannot say that the drive gear would be identical.
My brother-in-law had two gas Super 90s, replaced the engine in one with a Perkins 4-236 diesel from a MF 410 combine. He has the old Continental sitting inside his machine shed in SW Minnesota. If you have a number off of your distributor I can look at his when I go down there next week. I would think that Continental would have the same gear across all models but I am not sure. What year is your 230?
Ed Lotterman
03-09-2006 21:05:38
You don't say where you are but there are lots of tractor salvage places you can check on the net. Try Scott Kent at [email protected] or
[email protected]
Is this one with a clip on distributor cap or a screw on one?
