MF 135 Hydraulics
Robbie Franklin
06-19-2000 18:06:30
We have a MF 135. The hydraulics go up very slowly and won't go back down. We have replaced the lift cylinder, piston, seals, and taken it to the dealer to adjust. Any ideas?
Jack in NB
06-20-2000 14:43:45
 Re: MF 135 Hydraulics in reply to Robbie Franklin, 06-19-2000 18:06:30
Hello Robbie -
If you're talking about the 3-pt lift, it sure sounds like linkage out of adjustment.
Oil flow both in and out of the under-seat lift cyl is controlled by the pump control valve lever at the back right of the internal pump. If the pump were bad, you could have have slow lift but a fast drop if the lever is being moved full travel. Slow lift and no drop is possibly caused by very little movement of the internal lever.
This is visible from the inspection plate on the right side (has response control and oil level stick) but there are some tricky components in there, so I wouldn't remove it unless you have a shop manual.
You'll have to drain a couple of gallons of oil, or run the right wheel up on a block to prevent an oil spill.
Hope this helps.
