MF 175 Transmission Fluid Level
Ken Jackson
03-06-2006 21:18:29
The manual says that the transmission takes 8 gallons of fluid. How far should the level be below the check opening?
Ken Jackson
03-07-2006 10:39:11
 Re: MF 175 Transmission Fluid Level in reply to Ken Jackson, 03-06-2006 21:18:29
Thanks for the help. I stepped up from a "baby" 8N and have a lot to learn!
Big Dean
03-07-2006 08:00:33
The transmission, hydraulics and differential are all a common reservoir they fill through the big plug just to the left of the shift levers and check at the dipstick in the access plate by your right heel
Don-Wi
03-07-2006 07:10:34
There is a dip stick by your right heel, that is your fill level.
Donovan from Wisconsin
TomTX
03-07-2006 06:07:56
Ken, my MF690 has a small dipstick for the transmission, but your 175 may have a plug you remove and fill until it runs out. Do NOT just try to go with the stated capacity. Someone will no doubt have an exact answer for you. Tom
