Rebuilding my tea 20
Ian Orser
03-06-2006 07:38:01
I have torn ny 1950 tea 20 engine appart and want to rebuid it. Was considering replacing the sleeves but see in my book you need a special puller. How can I pull the sleeves without the tool.Or must I use it..and is there any tricks to it?
Bill Brox
03-06-2006 14:41:06
 Re: Rebuilding my tea 20 in reply to Ian Orser, 03-06-2006 07:38:01
Oh dear, so I was terribly wrong when I used a 12" 1 x 1 1/2" piece of wood, and a large hammer. Put the piece of wood up from the underside, on the edge of the sleeve, and gave it a very light knock... and the sleeve was loose and I continued and soon they were all out of the engine. No harm, no damage, just marked the way they sit in, so that every sleeve could be put back together as they had been.
Bill
Jerry/MT
03-07-2006 10:15:51
 Re: Rebuilding my tea 20 in reply to Bill Brox, 03-06-2006 14:41:06
Whatever works, Bill!
Jerry/MT
03-06-2006 11:20:42
You can probably make your own tool out of a piece of pipe and a length of all thread and a couple of small steel bars and a couple of nuts. the pipe has to be bigger than the OD of the sleeve, the lower bar has to match the sleeve OD and the upper bar has to be larger than the pipe OD. The lower bar rests against the bottom of the sleeve, the upper bar sits on top of the pipe which sits over the sleeve. The nuts hold the bars on the all thread. By turning the upper nut, you shorten the distance between the two bars, thus pulling the sleeve out. hope this helps.
