power steering m f 250 leak?
scott ind.
03-01-2006 15:55:00
my 250 has a leak in valve on the steering column. It comes out the top where the plunger goes up and down.I took it apart and all the o rings look good. I have look for shop manual but they are real pricey. Any help would be great thanks Scott
mn.Chuck
03-02-2006 14:15:24
 Re: power steering m f 250 leak? in reply to scott ind., 03-01-2006 15:55:00
Did you check the two "sealing rings" An O ring
is in the upper part but it would be hard to tell
wear on those sealing rings. Probably need these
parts: 1-1850234 M1 O ring, 1-1850 031 M1 sealing
ring, 1-1850 032 M1 and maybe a 1893 620M1 gasket.
E mail if any questions. Chuck
scott ind.
03-03-2006 12:59:51
 Re: power steering m f 250 leak? in reply to mn.Chuck, 03-02-2006 14:15:24
Chuck I went back though it and checked the top o ring and it looked a little small in dia. so I replaced it with a metric o ring and that fixed it this tractor was remanufacted in 2002 and they may have not put the right one in then but it works great now thanks for your input
