Massey 50 Hi-Arch?
Massey 50
02-28-2006 17:01:06
Can anyone tell me if the Massey 50 that I am restoring is a "Hi-Arch". I have not come across any numbers on the tractor to tell me and I can't go by the tires because I have a mis-match set of tires on it. Is there a way to tell?
mn.Chuck
03-03-2006 18:31:33
 Re: Massey 50 Hi-Arch? in reply to Massey 50, 02-28-2006 17:01:06
Yes, there is a 1500 RPM trans and a 1700 RPM
transmission. Chuck
Bob N.Y.
03-01-2006 16:37:12
If it has 38" wheels on the back, it is a high arch. If it has 24" or 28" wheels, it is a standard.
Massey 50
03-01-2006 17:03:55
 Re: Massey 50 Hi-Arch? in reply to Bob N.Y., 03-01-2006 16:37:12
Other than the wheels, is there any difference in the motore, transmissions, etc.... My wheels and serial number don't match.
Bob N.Y.
03-02-2006 17:40:45
 Re: Massey 50 Hi-Arch? in reply to Massey 50, 03-01-2006 17:03:55
There must have been a difference in gearing somewhere to compensate for the difference in tire diameter. Maybe Big Dean could elaborate on this. Of course, the front spindles are taller on the high archs.
Lou
03-01-2006 08:23:52
I saw a picture recently that showed a Hi arch 50. The vertical part that carries the wheel ( I dont obviously know what its called ) But it is higher than the front wheel when viewed from the side. If theres nothing above the wheels you dont have a high arch. Hope this is understandable.
mn.Chuck
02-28-2006 18:25:16
The serial number plate to the left of the steering wheel on the dash will tell you. If the
s/n starts with a "S" it is a utility. If it
starts with an "R" or "T" it is a row crop. If
it starts with a "C" it is Hi-arch. If it starts
with a "J" it is a Multi-purpose. The 50 series
in it's different configurations was sold with
24" 28" and 38" rims. The 24" n/a with power
shift rims-the others were. Mostly the parts book
refers to Hi-clear(38") and low clear(28") Chuck.
