240 masseyferguson
scott3826
02-26-2006 20:30:47
a friend just got a 1994 240 massey with power steering. i can turn the steering wheel either direction and the tires don't turn and the steering never locks out. i cracked open the fittings at the steering pistons one at a time and turned the steering each time, and it put out very little fluid and would never stop bubbling air. one more clue- it took 5 gals. of hydraulic oil to get it back to the correct level. am i about to pull the steering sector? i welcome any comments or advice. thanks.
Thomas
02-28-2006 11:22:14
 Re: 240 masseyferguson in reply to scott3826, 02-26-2006 20:30:47
When you say it took 5 galls to fill the reservoir, I'm assuming that that has to be the back end. The steering pump is mounted on the engine (timing case) and has it's own integral reservoir. If the seal has worn at the front, oil leaks in to the engine sump until empty, hence no steering.
ben king
07-24-2006 20:04:02
 Re: 240 masseyferguson in reply to Thomas, 02-28-2006 11:22:14
hey
i am tired of paying someone to put a cluch in my 240 every year i want to get some info on how to do it myself, i am a poultry farmer and i know i am hell on a clutch when i clean out .please give me some help
thanks
ben king
Big Dean
02-27-2006 11:46:41
Hey Scott Before you start tearing into fill the power steering pump reservoir with the engine running with MF Permatran 3 or one of the universal Trans/Hyd oil that meets the same specs. With the plug out turn the wheels from stop to stop while keeping the reservoir full a few times. It sounds like you might have air in the system.
