MF 135 Diesel will not crank
Thomas in NC
02-26-2006 11:12:07
I have a MF 135 diesel that cranked as normal; After driving about 60 feet it cut off as if the fuel stop had been pulled. Tractor was not out of fuel(1/2 tank of fuel). Fuel pump almost new, fresh fuel filter, fuel system bled, has a good stream of air free fuel at all bleed off points. Does anyone have any ideas as to what might be causing the tractor engine not to crank and run? Thanks to all for your replies.
Big Dean
02-26-2006 12:25:23
 Re: MF 135 Diesel will not crank in reply to Thomas in NC, 02-26-2006 11:12:07
Have you loosen off an injector line compression nut and cranked the engine to bleed the injection pump head you should have fuel squirting out around the line. It sometimes takes up to 30 seconds of cranking to get fuel there. I have found things floating around in the tank like pieces of plastic, paper and cardboard. If you do have it will sometimes suck it down over the tank outlet and shut the fuel off. If your tank happens to have water in it the injection pump may have got a big shot of water that will sometimes shear the pump hear coupler. Just some of the thing I have seen cause that problem. If I can be of further email me
Thomas in NC
02-26-2006 12:50:08
 Re: MF 135 Diesel will not crank in reply to Big Dean, 02-26-2006 12:25:23
I have tested the fuel in the tractors tank and the fuel shows to be free of water. Also have opened fuel line at injector and fuel coming out there seems to be free of air. Thanks for your reply.
