44 engine???????
MeanMassey
02-25-2006 00:47:37
I'm in the process of building my 44 engine,does any body know what the crank endplay should be?I pulled the crank timing gear off and found shims I'm assuming to shim endplay,what I thought I would do is set up a dial indicator on the end of the crank and move the crank backward or forward to figure out where its at and add or remove shims to get to where it needs to be,but I'm not sure I'm right on the shims.Also what do the rods,mainsand head torque to?Any help is appreciated.Eric
W, ANGLEMYER
02-26-2006 12:49:08
 Re: 44 engine??????? in reply to MeanMassey, 02-25-2006 00:47:37
MARLOW YOU ARE WRONG ABOUT THE SHIMS THE H260 YOU SHIMED THE END PLAY WITH SHIMS BEHIND THE CRANK GEAR
marlowe
02-26-2006 14:40:21
 Re: 44 engine??????? in reply to W, ANGLEMYER, 02-26-2006 12:49:08
i'll be the first to say i was wrong . been a lot of years sence i did a 260
Tom Dold
02-25-2006 13:17:21
MeanMassey
J. Schweibert is correct. The shims adjust the crankshaft end play on the H260 engine. There are two brass thrust washers on the front main bearing. The shims behind the timing gear determine the end play. Check the clearance the way you described, and adjust for .006-.010 endplay with the shims. The later engines and the H277 used a center thrust main bearing, and therefore endplay is predetermined.
Torque:
Head 130-140 Rods 85-90 Mians 100-110
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349 605-772-4541
[email protected]
Mean Massy
02-26-2006 13:17:27
 Re: 44 engine??????? in reply to Tom Dold, 02-25-2006 13:17:21
Thanks to all of you that replied,the info is appreciated.Eric
J. Schwiebert
02-25-2006 10:22:36
Early H model Continental engines used that set up to adjust crankshaft endplay. Later Continental engines used a flange type trhust bearing. Is this gas or diesel and a 260 or 277 engine?
marlowe
02-25-2006 07:28:56
them shims arn't end play shims they shim the gear your end play is taken care of buy the center main or rear main bearing [not sure of the engine you have if oem .
