Rework a new carb?
22 Skidoo
02-24-2006 06:03:18
My 22 M-H needs a new/rebuilt carb. I've had no luck finding a good Zenith TSX-34 carb to fit it.
Has anyone out there taken a new TSX-34 that's available to fit other tractors and reworked the linkage (tig weld brackets) to work okay on a 22 Massey. There must be a way out! What is it?
jrsn
02-24-2006 17:27:38
 Re: Rework a new carb? in reply to 22 Skidoo, 02-24-2006 06:03:18
...A-13, A-145, TO-20, TO-30, TO-35, 16, M-S TSX-34, TSX-248, TSX-272, TSX-308, TSX-309, TSX-312, 20, 21, 30 TSX-361, TSX-361 A, TSX-458, TSX-541,... ...35, 40MH-50, 81, 82, 101J, 102J, Z-145 M-S TSX-28, TSX-34, TSX-55, TSX-88, TSX-155, TSX-188, TSX-683, TSX-882 (6195-A, 6307-A, 6371-A, 6401-A, 6683-A,...
35% Fri, 26 Oct 2001 19:33:59 GMT>Link
Try here..ray-s
Glen in TX
02-24-2006 08:31:10
The Marvel Schebler TSX-34 is replaced by a newer Zenith 12522. The Zenith is a universal fit replacement carb and will come with universal linkage you can adjust and make fit. Aluminum step down adapter rings for air horn if needed are available from Zenith also. C29-2067 is part # for the TSX-34 throttle shaft assembly and it's still in price sheet for $40 as are some other parts for the MS carbs.
22 Skidoo
02-24-2006 10:36:06
 Re: Rework a new carb? in reply to Glen in TX, 02-24-2006 08:31:10
Thanks for the info, Glenn. Where do I go to purchase this carb that you describe?
Glen in TX
02-24-2006 11:37:12
 Re: Rework a new carb? in reply to 22 Skidoo, 02-24-2006 10:36:06
They probably sell them here on YT parts or several of the other tractor supply places where you are at. I can get parts but can't compete with their new carb prices. The new Zenith will work good but sometimes the universal linkage can be a pain to get set up depending on what application. It's adjustable and reversible from side to side and shaft sticks out farther and after you get is set where you want it you can saw off the extra throttle shaft length if needed. You might also need a air horn adapter so ask them throat size when you buy one. Kit, float, throttle shaft, and needle jet are still available for the TSX-34 also. Some tractor supply places could have some NOS TSX-34 carbs also?
