Massey Harris? tractor
n2mopars
02-22-2006 21:02:28
third party image
Can someone help me identify what I have here?? I think it is a Massey Harris. I can"t find pictures of any similar...Thanks!
Kevin Bismark
02-23-2006 17:35:03
 Re: Massey Harris? tractor in reply to n2mopars, 02-22-2006 21:02:28
Looks like a 44 to me, look on top of the transmition by the base of the pto lever and you just might find the serial number, then you will know what you have for sure..
Kevin
Jim - Illinois
02-23-2006 15:08:30
A word to the wise--If you are going to use what looks like the PTO post hole digger, rap an innertube tight around that belt pulley and fasten with zip-ties, or take it off. It will fly apart and alltho it is just paper, they hurt. (Not to mention the nails)
mn.Chuck
02-23-2006 15:06:11
The hood line is of a 44 or 44 Spec. Look at the
flat spot on block under the manifold. It should
say HD 260 or HD 277. A 44 is only a HD 260 but
a Spec could be either. The rear portion of the
frame should have a black and silver riveted
plate with model info. The rear portion under-
neath the frame will have a date embossed on it.
The month and year anyway. The wide front is most
likely an aftermarket-I see none in all my 44 books like it-Poss. Schwartz or other. This is a
diesel tractor. The filter may be a fuel filter-
they had different configurations depending on if
two stage or three stage w/ A.P.E inj. pump. Chuck
Dave_Id
02-23-2006 13:23:16
....not to mention, belt pulley is in very rough shape
marlowe
02-23-2006 12:39:22
looks like a 44 but the oil filter is in the wrong spot
Kevin Bismark
02-24-2006 17:09:14
 Re: Massey Harris? tractor in reply to marlowe, 02-23-2006 12:39:22
Yea, I had to really look to see what that was, wonder how it got over to that side of the engine, never saw one on that side on a 44 before, maybe the guy didn't like walking to the other side to change it..
Dave_Id
02-23-2006 05:56:51
It"s a Massey Harris alright. 30 or 33, I think. I don"t think it"s a 44, the engine looks too short. Does it have a tag that you can post a ser. number? Do some scraping on the paint on the top of tranny by your left foot, if tag can"t be found, ser. number is stamped there somewhere.
Dave_Id
02-23-2006 11:17:48
 Re: Massey Harris? tractor in reply to Dave_Id, 02-23-2006 05:56:51
Looking a little closer at the sheet metal, I believe it's a 44
Harris Guy
02-23-2006 12:16:32
 Re: Massey Harris? tractor in reply to Dave_Id, 02-23-2006 11:17:48
Appears to be a 44D High Arch,probably 40K series,
but the front axle is about four years earlier,
the weak steering support was only a short run, as MH offered a complete upgraded concept tubular
WFE. If the disc throttle is original, this 44 is
late '52, or a '53. Front rims from a car, lamp
from a truck(?).
Dave_Id
02-23-2006 13:44:46
 Re: Massey Harris? tractor in reply to Harris Guy, 02-23-2006 12:16:32
I had a 33 diesel with wfe.. what a welded mess that front end was. The guy who had it before me must not have had a very good supply of steel for patches. He even had a tire iron welded to it to support one break. The upper link for the 3point hitch was laughable, too bad I didn't get any picures of it, It was really funny..
