Pony shuts off
Jason(Pa.)
02-22-2006 15:50:02
Hello. the other day it was nice out so I thought I would fire up the old Pony to let her run a while. Started up fine and ran for a few minutes and shut off. Had gas in tank. I cranked it over and it started up and shut off after a few secounds. The more I try to start it the worse it gets. I got good fuel flow to the carb. I tryed pulling out the choke to try and keep it going but didn't help. I pulled the tube off and try to run it. Still did the same. I did however need a new Battery and I put a 8 volt in it. This wouldn't effect say the 6 volt coil would it? Im almost leaning tords a coil problem cause if I let it sit over night and fire it up it will run the longest after a good rest. Any thoughts?
Spitz
02-23-2006 08:27:59
 Re: Pony shuts off in reply to Jason(Pa.), 02-22-2006 15:50:02
had the same problem with mine. Took or carb and cleaned it. purrrrred like a kitten after.
Jason(Pa.)
02-23-2006 13:01:01
 Re: Pony shuts off in reply to Spitz, 02-23-2006 08:27:59
Im thinking thats whats wrong with mine too. I'll find out tonight. i don't run this tractor as mush as I should. Its a show tractor only so it sits alot and probably got gunk in it. Thanks!
The Dude
02-22-2006 20:20:31
If you let it sit and it runs the best then. "I" would suspect you aren't getting fuel into the bowl. You may have good flow to the carb but, it might not be getting in for whatever reason. When it sits it has time for the bowl to fill slowly. Last winter my needle got stuck. I'd put money on this being your problem. Just drop the bowl and give the float a little tug down.
Jason(Pa.)
02-23-2006 03:07:01
 Re: Pony shuts off in reply to The Dude, 02-22-2006 20:20:31
The more I thought about it last night Im thinking it is something fuel related. Thanks for the advice I'll mess around tonight with it. Thanks!!
Greg_Ky
02-22-2006 16:06:36
Carb. Icing ?
Jason(Pa.)
02-22-2006 16:18:47
 Re: Pony shuts off in reply to Greg_Ky, 02-22-2006 16:06:36
No it wasn't. Its kept in a heated garage and I had it running inside for a while. i never had a problem with the Pony icing up. thanks though!!
