Pony PTO direction
Clay in MI
02-20-2006 15:29:02
It was mentioned in a few posts that the Pony PTO shaft spins in the opposite direction compared to other makes. I haven't found this information in the manuals. Can anyone confirm this? Will this make the Pony incompatible with a pull behind rotary cutter, broadcast spreader, etc?
Clay in MI
02-22-2006 06:49:31
 Re: Pony PTO direction in reply to Clay in MI, 02-20-2006 15:29:02
Thanks everyone, that's what I needed to know.
Jason(Pa.)
02-21-2006 18:51:51
The Farmall Cub is the only one that turns counter clock wise. You'll be ok with attachments on your Pony
mh446
02-21-2006 09:56:14
i have a grey 54 pony and it turns clockwise as with my 1947 44-6 tractor
Bob
02-20-2006 21:01:26
I don't know anything about the Pony PTO, but, if it, in fact, does turn backward from most tractors, implements designed for a Farmall Cub should work, as the Cub PTO rotates backwards.
