Question for Big Dean
Lou
02-20-2006 08:57:26
First Happy Presidents Day to all, I hope you have the day off. Ive been reading lately about flushing engines with some kerosine or transmission fluid or other additives for sale. I have a MF 50 diesil the oil seems to get dirty quickly after I change it,should I leave it alone? or is flushing a none risk if done right? Thanks Lou
Bill Brox
02-21-2006 01:24:22
 Re: Question for Big Dean in reply to Lou, 02-20-2006 08:57:26
Hm... the reason the engine oil gets black so quick after an oilchange is mostly because the oil that remains inside the engine, the oil that never drains out mix with the new and fresh oil.
Let us assume that there is 1/4 pint of oil inside the engine after you have emptied it. Then you have a newly overhauled gas engine, never been run. And then you take 1/4 pint of the oil from the diesel tractor and pour into your newly overhauled gas engine, and fill the rest up with fresh oil, and start. In an instant the new oil in the newly overhauled gas engine will be as black as the oil in the diesel engine.
It is simply because the black in the diesel engine lubrictating oil is such a strong color.
It is like some spices for food... like the yellow you put in rice, it only takes a little of it to give the rice a very strong yellow color.
On the other hand... :-) This tells us all that a diesel engine is a MUCH dirtier engine than a gas engine.
As Dean points out, if you flush it, something might get loose and may cause more harm than just dirty oil.
I once saw a man buy a Nissan car with a diesel engine, and the oil was dirty. He bought some super cleaning engine oil, poured it in, drove about 1000 miles and emptied it. I have never in my life, neither before nor after, seen an oil so thick. He had the engine warm, and emptied the warm oil, and it was still like thick syrup. He used the same type of oil again, and it was better next time he changed oil.
I would never do that to my engine. He was mighty lucky...
Bill
Big Dean
02-20-2006 11:52:00
Hi Lou You are right about flushing the engine I have been into a few engines that were full of sludge and when they were flushed the sludge got in the crankshaft and plugged off the holes going to the one or more of the bearings. That is bad news when that happens. Just one of those thing I have seen on those engine through the years I would not have believed it could happen had I not seen it.
Lou
02-20-2006 12:57:51
 Re: Question for Big Dean in reply to Big Dean, 02-20-2006 11:52:00
Thanks Big Dean, dont think ill try that flushing idea any time soon. Lou
Jerry/MT
02-20-2006 10:06:38
I'm sorry if I'm pre empting Big Dean, but detergent oils are supposed to hold particles an suspension so the filter can take them out or keep them in suspension to prevent sludge formation. It's very common for diesel oil to turn dark a few hours after an oil change depending on how often the original owners changed the oil, the ammount of blow by from the cylinders, etc. If it worries you, you may want to do your oil & filter changes oftener. I have a Powerstroke with 65K miles on it and the oil never really turns black between oil changes and stays brownish for quite a while after an oil change. But it's barely broke in so that's why it does that. My tractor is altogether different but it does get dark by the time I change the oil in it.
Lou
02-20-2006 11:08:27
 Re: Question for Big Dean in reply to Jerry/MT, 02-20-2006 10:06:38
By all means Jerry wade right in, the waters not too deep. Im using 15 w 40 which I believe is the right oil. Just seems to me you could get into a lot of trouble with this flushing idea.
