cav diesel injector pump
markey
02-17-2006 11:19:51
HI can any one advise on serviceing a cav diesel injector pump I have pressure and no sign of air at bleed points, but no output at injector line. It just seems as if engine stop is stuck is this possible ? Any help welcome TA MArkey.
Thomas
02-18-2006 13:01:19
 Re: cav diesel injector pump in reply to markey, 02-17-2006 11:19:51
The metering valve is a high precision part, it sits in a bore in the rear of the pump and controls fuel flow. It can stick causing the symptoms you describe. Take it to a specialist, as you need clinical cleanliness and may do more damage to an otherwise salvegable pump.
phil25
02-17-2006 14:33:44
Wondered what happened to you and the situation:)
Sounds as noted "stuck" time for an injection shop visit, unless your lucky to remove the top cover and discover a simple problem to solve.
Hard bullit to bit but shop time will solve futher fuel/pump/injector problems happening later on, and ease your mind as to what you have and should/could of done, been there paid for that:)
good luck
markey
03-01-2006 14:17:02
 Re: cav diesel injector pump in reply to phil25, 02-17-2006 14:33:44
TA FOR ALL UR HELP, PROBLEM IS SHUT OF VALVE STICKING ON EVERY ENGINE STOP OR RAPID DECELARATION . CURE IS TWO TAPS ON OUTSDE OF FUEL PUMP!!!!! WORKS EVERY TIME. TA Markey
barnrat
02-17-2006 11:39:16
Sounds seized up to me.
