Transmission input shaft.
DKHALL
02-16-2006 16:17:10
I have A 1962 MF 50 I took the tractor apart to replace the clutch and noticed that with the tractor in gear I can turn the input shaft to the trans. A full round before it starts to turn the wheels. Should it turn this much if not should I look for worn parts in the tranny. Thanks for the help.
DKHALL
02-17-2006 08:53:36
 Re: Transmission input shaft. in reply to DKHALL, 02-16-2006 16:17:10
I played with this a little and found that I had 1 full turn in 3rd gear about 1 and 1/2 in 2nd gear and 2and 3/4 turns in 1st gear (low range) It just looks to be alot of extra play. maybe its just me. Thanks for the help.
Big Dean
02-16-2006 19:54:40
Before the wheels start to turn you have to take up all the slack in the transmission the two speed planetary on the back of the transmission the slack in the driveshaft coupler the slack in the ring gear and pinion the slack in the spider gears in the rear end and the slack in the planeataries at the end of the axles a little in all of these will add up to quite a bit at the transmission input shaft.
