Firing order on 165
Kevininpeel
02-14-2006 16:08:51
I am doing a tune up on my 165 Perkins gas and need to find out the firing order of the tractor. Which cylinder is #1 fan end or trany end and which terminal on the distributor is #1 also to put it back together properly. I think that it was wired wrong since I got it. A diagram would be great if someone had one. I would really appreciate the help as I have some snow in need of blowing and its my only tractor.
Thanks in advance for the help!!!!
Kevin
msmith6
03-19-2006 14:03:17
 Re: Firing order on 165 in reply to Kevininpeel, 02-14-2006 16:08:51
the perkins gas is the same as the continenetal
Leland
02-14-2006 21:37:02
if it's a 4 banger 1-3-4-2
Don-Wi
02-14-2006 20:45:12
#1 is always the front end of engine by the fan. As far as timing I don't know for the Perkins, but to find out which one on the cap is #1, find TDC compression stroke for the #1 cylinder, then where ever the rotor points is #1. Easiest way I found to find TDC compression, is to put a soft plug in the spark plug hole, crank it till it shoots out. it'll be a little bit past TDC, but it should be close enough to start it up and time it from there.
Donovan from Wisconsin
