french mf 130
markey
02-13-2006 13:32:50
hi can any one help my mf 130 with a perkins a4 107 engine wont start unles i use easy start, it appears to be starved of diesil but it sprays from the blead points on the fuel distributor but not from the injector unions..
has any one got diagrams of the fuel distributor? Thanks Markey
phil25
02-13-2006 17:06:44
 Re: french mf 130 in reply to markey, 02-13-2006 13:32:50
I have the french 25[ 4-107] just about a exact twin of your unit. A couple of things to look at: Is there any air coming out at the bleed points on the fuel pump, should be a steady stream, bubble free.Might have a soft rubber seal ring at one of the fittings/ or filter seal is leaking[ changed filter lately?]
Once running its ok? might look into injector cleaning/resetting if it hasen't been done recently, a bad fuel spray will be hard to start and the "canned assist" may cause more trouble.
What about the fuel pre-heat element in the intake manifold,is it working? its a good item to have working instead of the "canned assist", works good on mine.
Little things to check, before getting into the actual injector pump itself.
good luck
markey
02-14-2006 13:36:38
 Re: french mf 130 in reply to phil25, 02-13-2006 17:06:44
Hi PHIL25 and all watching
Thanks for ur reply to [hi can any one help my mf 130 with a perkins a4 107 ]
can u give me more info on injector cleaning/resetting, and can i crank engine with injector outboard so i can see if any fuel is being delivered? I take your point about engines getting addicted to the can, the heater is a1, and i have no air in system..
Ta Markey
