need MH 50 stock rear rim part number
Jobyrn
02-10-2006 15:49:03
need MH 50 stock rear rim part number.
I need help confirming the original stock part number for a rear tire rim - size appears to be 10x28 - on a MH 50 tractor (circa 1956-1958 or so). The outer rim is demountable from an inner pancake 'hub' that fastens to it with six hoop flanges with through bolts. I need to buy a new outer rim because the original steel one rusted through from calcium chloride leaking out. The new one is listed as aluminum which would be an improvement if they match. Anyone got a manual you could check for me? Many thanks.
mn.Chuck
02-11-2006 10:04:52
 Re: need MH 50 stock rear rim part number in reply to Jobyrn, 02-10-2006 15:49:03
Original MH part # for the non-powershift
rim would be 180863M91. I believe the ref.
to aluminum rim would mean just the finish.
Chuck
