pto
geovair66
02-06-2006 21:24:17
hey all can anyone tell me what the pto/engine horsepower is for a 1964 model 50 high clearance tractor. will it pull a bailer for square bales? thanks.
Lester Elwood
02-07-2006 05:33:05
 Re: pto in reply to geovair66, 02-06-2006 21:24:17
Hi Geovair66 This tractor should have a Z134 Continental eng. It is rated at 32hp.If its been rebuilt it could be alittle more.I have a Ferguson F40, which is basically the same tractor with different tin on it.You should have no problem pulling a square baler with your tractor.When i was lad my dad bought a new 1958 TO 35 and we pulled a 14T JD baler with it on a Vermont hill farm and never had any problem getting around. These are great trators and very cheap to run. My F40 burns a gallon of gas an hour running a 6ft Woods Dixie Cutter brushog.Hope this helps you.Good luck and enjoy. Lester
Mighty Fine
02-07-2006 05:32:48
Assuming you're talking about an MF50, gas or diesel, it should weigh in at around 32 or 33 HP, depending on which specs you look at. Bottom line, around 32.
They've pulled a many a baler in their day. Should still handle a small one.
