can i put a ad4203 where a ad3152 is?
jason2078
02-06-2006 17:08:13
I have a massey ferguson 2200 treever log skidder/forwarder with a ad3152 motor that just aint enough horsepower. will a ad4203 bolt up to the transmission on the ad3 152. the transmission is out of a massey ferguson 165 i believe. i wear the the ad3 152 out in six to eight months of working it in the woods everyday. any help would be greatly appreciated.
marlowe
02-07-2006 16:16:24
 Re: can i put a ad4203 where a ad3152 is? in reply to jason2078, 02-06-2006 17:08:13
i looked in the book and it looks like you should have all kinds of room out front for a longer engine [lots of grill space] i don't think david p knows what a TREEVER is. we had a 203 for years but we got it used and it had a little cummens in it but that was 20 years ago some one changed it before we got it. i think treefarmer made them for massey and they used a differnt engine
jason2078
02-07-2006 16:34:26
 Re: can i put a ad4203 where a ad3152 is? in reply to marlowe, 02-07-2006 16:16:24
is a 203 a cable skidder or did you have the 2200 treever forwarder like ive got
marlowe
02-07-2006 18:32:59
 Re: can i put a ad4203 where a ad3152 is? in reply to jason2078, 02-07-2006 16:34:26
the 203 is just like the 2200 i don't know what the differance was they look the same and it was not made by treefarmer it was made by GAFFNER CO. of michigan
parts man
02-06-2006 19:50:03
Jason, the 203 will bolt to the transmission, but be aware that it will be pretty much 1/3 longer compared to the 152.
jason2078
02-07-2006 05:08:45
 Re: can i put a ad4203 where a ad3152 is? in reply to parts man, 02-06-2006 19:50:03
thanks for replys. will the same clutch and pressure plate work? as far as fittings? are you talking about the piece that is between the the radiator and motor will be different? if so would have to convert radiator and front piece over to something that would bolt to larger engine?
DavidP,South Wales
02-07-2006 11:03:43
 Re: can i put a ad4203 where a ad3152 is? in reply to jason2078, 02-07-2006 05:08:45
Hello again,
My books show that the flywheels are different (may be change of number). The clutch components for the 11" clutch however will be the same other than the coil springs and belleville spring. Assuming that you are able to fit the engine with a '203' axle casting you may well run into all sorts of problems with the steering linkage, the fitting of the axle and the length of the front wheel spindles..... .why not buy a bigger tractor????? ????? ???
Would a '203' MF165 fit your logger chassis? A long shot but you never know.
DavidP
jason2078
02-07-2006 12:28:20
 Re: can i put a ad4203 where a ad3152 is? in reply to DavidP,South Wales, 02-07-2006 11:03:43
as long as i got the complete flywheel/clutchdisc and pressure plate assembly the input shaft and transmission should work right? The steering is articulated in middle so that wont be a problem. In your books does it show the axle holder for the front end (which mine doesn't use for axle but does hold hyd pump and radiator on the end of it) be the same bolt patterns as as the the 3 cylinder front of motor?
David Perrin
02-07-2006 00:16:39
Hi,
In addition to 'Parts Man's' comments don't forget that the fittings at the front will be different where it bolts to the axle casting.
DavidP
