MF-35 Deluxe Diesel Fuel Gauge Pressure Switch
Dean
02-04-2006 16:07:21
My local MF dealer tells me that this part is obsolete and no longer serviced. It turns the power on to the fuel gauge when the oil pressure comes up so that the gauge circuit does not run the battery down when the engine is not running.
One of the terminals on mine is broken off. I hooked the gauge circuit up to the headlight switch and the gauge works when the lights are on but I would like to replace the switch. Anyone know where I can get one?
Thanks, in advance.
Dean
benny2
02-06-2006 12:18:47
 Common part forklift Re: MF-35 Deluxe Diesel Fuel in reply to Dean, 02-04-2006 16:07:21
Pressure up on switch is commonaly used on hour meter on Forklifts and industrial engine power supplies.
Dean
02-06-2006 15:22:46
 Re: Common part forklift Re: MF-35 Deluxe Diesel F in reply to benny2, 02-06-2006 12:18:47
Thanks, Benny. Good to know and will give me some more leads.
Dean
phil25
02-05-2006 15:15:42
 Re: MF-35 Deluxe Diesel Fuel Gauge Pressure Switch in reply to Dean, 02-04-2006 16:07:21
Too bad the dealer can't supply, i suspect there are suppliers linked through this site and/or have a parts supply[ napa] look through their product book. I found a switch for a welder, but you have to look and read the info, lots to choose from, as to contact operation and operating pressures, etc
hope it helps
Dean
02-06-2006 04:29:50
 Re: MF-35 Deluxe Diesel Fuel Gauge Pressure Switch in reply to phil25, 02-05-2006 15:15:42
Thanks, Phil. I have checked a couple of other potentital sources including NAPA. The store owner, who I have known for 25+ years just shook his head and said "dealer." I was hoping that someone might have one on a parts tractor. If I cannot find one, I will figure something out. Right now it is hooked up to the headlight circuit so that the gauge works when the lights are on.
Dean
